Announcements
Calculated Value
mattpick10
Calculated Value
mattpick10
Hi all
Can anyone help?
I want to create a schedule for give me a total number of spirals required.
For example I have a total of 10739mm of 300 diameter spiral tube which comes in 3meter lengths to I want to add a parameter with a calculated value to divide length by 3meter ( 3000mm ) and give an value of 10.739 lengths required.
thanks in advance
Accepted solutions (3)
Replies (13)
iainsavage
Need more info to help you.
Why are you multiplying by 3 to get the wrong number of pieces? If the overall length is 10739mm  and the pieces are 3000mm is the answer not just 3.58, then use roundup to get 4?
How are you sorting the schedule? Is it by the Size field?
I assume you have unchecked the Itemise Every Instance?
Have you activated the display of total quantities in the No of Spirals Required field?
If you could maybe give more info someone will be able to help solve this for you.
robert.klempau
Hello @mattpick10,
You need a Calculated Integer parameter.
In Revit, you need to be aware that the parameter units must be correct.
To get your number of 3-meter spirals you need to divide the Length by his own units.
(Length / 1 mm)
Then you get a number value.
use the formula below in your parameter (Type Integer)
roundup((Length / 1 mm) / 3000)
See my results for a 3meter Pipe calculation below:
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
iainsavage
@robert.klempau wrote:
Hello @mattpick10,
Is it not easier to just do roundup(Length/3000mm)?
mattpick10
Thanks for the replies
Really don't know what I am doing wrong here for something that should be really simple. I am obviously missing something. I have tried the formula 'roundup((length/1mm)/3000) bur still get an answer of 1. See below image
iainsavage
Hard to tell from your image but one parameter is “No Spirals”, the other is “No of Spirals” - are you sure you’ve got the correct field in the schedule?
If possible can you upload your model or part of it?
mattpick10
I just made a new calculated value called No Spirals meaning number of spirals.
I have uploaded my model the schedule in question is MEP Fabrication Ductwork Schedule
Any help would be much appreciated
Thanks in advance
robert.klempau
Hello @mattpick10,
You just did fine with your schedule. 😀
the only thing you need to change is to check the 'Itemize every instance' option in the Sorting/grouping Tab and calculate totals for the 'No Spirals' parameter.
Unfortunately, you can't use the formula when the length parameter is totalized.  Would be great if this could tough.
Kind regards,
Robert Klempau
Cadac Group AEC BV
amarkonathala
I checked your file
In the Schedule U Updated the Condition to Calculate totals for Length
But For No of Spirals U didn't Just Update it to Calculate totals u may find
Thank u..
robert.klempau
Hello @amarkonathala,
Great. 😀
so your schedule with the calculated parameter now just works fine.
With 'Itemize every instance' turned off, you get the result below.
In the example below I added a conditional format so I can see the lengths that are less than 3m and I added the total wast calculation.
I hope this helped you solve your issue.
Kind regards,
Robert Klempau
Cadac Group AEC BV
mattpick10
Yes turning off the itemize every instance worked
Thanks for the help much appreciated
thefekry
I would like to thank you for such a great illustration
robert.klempau
Hello @thefekry,
Your welcome,
I am glad that I could help. 😀
Kind regards,
Robert Klempau
Cadac Group AEC BV
Tommy_S
Hey i was making the same thing; a schedule to calculate the total amount of ducts to be ordered, the above solution is not sufficient unfortunately.
If you for instance have a lot of short pieces (see example below) every piece will be counted as a complete 3m length which is of course not what you want to order.
It's such a pity you can't make calculations on sorted totals or has anyone figured out a trick to make it work?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
