Building Construction Type
Jessicas
Jessicas
Is there a way to change the default settings or create a secondary construction type other than <Building> that has the Analytic Construction that we want? We do over 200 units a year and this is not something I want to do 200 times over.
dzanta
Building Construction - specifies the type of constructions. Click to open the Building Construction Dialog, where you can specify the constructions for the <Building> construction type parameter.
These constructions specify the construction materials that define the stated U-value for the constructions. When using the Heating and Cooling Loads dialog to run a loads report, you can also adjust the building constructions.
Note: <Building> is the default construction type parameter. You cannot rename or delete it. However, you can create a new construction type parameter by modifying the space properties or using the Heating and Cooling Loads dialog.
see image
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
