In my example I have a roof gravity ventilator that draws air from a plenum below. I used a rectangular duct (from the roof hood duct connector built down). I will tap a few lateral ducts and that should work fine since they tap into the rectangular duct. but the larges duct would tap from below. Ideally I can tap that in.
But if I close the bottom of the duct with an endcap, the taps don't seem to work on the end-cap. I don't want to do a transition since that really isn't a transition unless I can find or make one that will have a 90° transition. In real life thsi will be a bell mouth for round duct going into the plenum, but the bellmouth could be shown in a 2-D detail and doesn't need to be into he model.
This should work with different size and type of ducts and also ducts that are not in the center. I don't think including that into the hood family would work since I want to run multiple ducts in (and the flows should add up). And the number and size of ducts going into the plenum will differ.
Is there a way to make an endcap behave like "duct" regarding taps? Or can the duct be closed with something that is just "duct"?
Revit is calculating the flow, so i need a solution that works like the plenum and doesn't just look like one.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
