Automaticaly change pipe accessory position
david.fritzS9YU2
david.fritzS9YU2
Hi all,
Question from Revit newbe: Is it possible to change a position of a given pipe accessory piece fast? maybe automatically?
Problem: I have a project, where someone misunderstood the way of installation and I have to adjust the position of pipe accessories.
HRV 1.jpgThis way it is in the project.
HRV 2.jpgAnd this way it should be
changing every piece manually is time consuming and there are over 800 instances.
Can someone advise here?
L.Maas
No, there is no automated way. Someone with experience in Dynamo (visual scripting) might be able, depending on the situation, to write a script that would (partially) automate this
Louis
Please mention Revit version, especially when uploading Revit files.
