Autodesk Point Layout problem
Has anyone experienced problems with Autodesk point layout deleting points immediately after placing them? We are experiencing this issue and the error message that it give is requesting permission from ID 1247 which turns out is the Project Information Tab, which doesn't make any sense since there are no relevant parameters in there at all. Other than that I think the problem might be that I have 4 people trying to create points at the same time and APL is having trouble creating points with the same PointNumber parameter? which i need to know if that is a black-box problem or perhaps a licensing issue?? because the PointNumber is an instance parameter, and if it is an instance parameter, then Revit wouldnt care if too points had the same point number or not. So why then, is it deleting them? Any advice would help a lot! Thank you.
