Assign color to pipes
Hello
I hope somebody can help me with this, I am trying to apply color (say, as painting it, not material color) to pipes in Revit
Thanks!!
kadmonkee
have you tried assigning colors as graphic overrides in a Pipe System?
In the project browser browse to Pipe Systems/ Pipe System/ Domestic Cold Water- select Type Properties and go into the Edit button for Graphic Overrides here you can assign any color, Line weight, and Line Pattern  for any system
see attached images.
I hope this helps
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
fabiosato
You can assign materials in the segment setting.
Fábio Sato
robert.klempau
The solutions above are based on the Pipe or Duct System Type. Assigning Graphic Overrides will have effect in all your views if have not used Graphic Overrides with filters in your views.
In your view you can set filters based on the System Type or even System name if you like.
It is an old method I used before you had the Graphic Overrides in a Pipe and Duct Systems.
I use this method to get the black outlines in my 3D views.
See example below
  1. Go to your 3D view and click Visibility/Graphic Overrides
  2. Go to the Filter Tab
  3. Click Edit/New and create a new filter
  4. Add that filter to your View filter and change the Overrides…
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
