Asign Revit Categories to IFC Class Name
QuangNguyen-ICE
QuangNguyen-ICE
Dear Team,
Please help me,
In the original setting export IFC of Revit, there are multi Revit Categories asign to wrong IFC Class Name, so please help me how to determine right IFC Class Name for all Revit Categories.
And how to find out all revit categories for all IFC Class from link below
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Example: which revit elements will be assigned for IfcActuatorType
L.Maas
In Revit you will map categories of families to IFC classes.
There are two methods:
1-In the IFC options set the desired IFC class to the corresponding Revit (sub)-Category.
2-Add a IFCExportAs parameter to the family to override the IFC options.
Second method allows you to set different classes to each element.
Louis
Please mention Revit version, especially when uploading Revit files.
QuangNguyen-ICE
Thanks @L.Maas
However I don't know which IFC class name will be assigned to which revit categories.
Exemple: Revit Mechanical Equipment will be assigned to what IFC Class Name, I can't find out the name same with this Revit Category Name, and many more revit categories like: Grid, Plumbing Fixture,....
Please advise and give me an example in this case.
L.Maas
Have you looked at the IFC Options in Revit (File->Export->Options->IFC Options)?
There is were you find how a Revit category is mapped to an IFC class
If you want a category to be mapped to a different class then you can fill that in in this window.
Louis
QuangNguyen-ICE
Thanks @L.Maas
Please spend your time to have look on my video for more detail about my issue
Hope it useful and enough information about my issue that I met.
L.Maas
Ok, I see you are reimporting the IFC file back into Revit.
Then have also a look at the import IFC options.
Like with the IFC export option, here you can map IFC classes to Revit categories.
As an example; you can see that in this case IfcSpaceHeater is imported as Mechanical Equipment.
So if I export the Revit files to IFC where I map mechanical equipment to IfcSpaceHeater and then import the IFC back into Revit it will come back as Mechanical Equipment.
So if you need to export to IFC and then import back to Revit you will have to coordinate between the import and export mappings.
Normally you would only export to IFC (not reimport it back into Revit), to be used in different (specialised) IFC software
Also have a look at the (free) IFC 2017 add-in. It improves the usability of IFC export/import.
Louis
QuangNguyen-ICE
Thanks @L.Maas
