applying space Tags
applying space Tags
applying space Tags
How to apply space Tag to multiple views?
dzanta
space tags are annotations.  annotations are view specific.  you can tag all spaces in a view via place spaces automatically command but this is restricted to per view at this time.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
MichaelBussiere2
Thank you for your post. In this case you can tag multiple spaces/rooms at once in a single view, but you will need to be in each view to continue tagging. I have included a helpful link below with details on tagging at once. I hope this helps.
Tagging Rooms at once: https://revitconvert.wordpress.com/2012/04/17/tagging-rooms-all-at-once/
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
thanks for reply..I can tag all on single view wanted to tag on multiple views...
MichaelBussiere2
Thank you for your reply. If you have the exact same walls in the views (duplicates) you could copy from one to another. The conflict comes up when you go form level to another level.  Outside of this, you would want to make it a view by view instance to reduce miscommunication from view to view. I hope this helps, and thank you again for your participation in today’s answer day.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
