An ideea for my situation..
Secttor
Message 1 of 8
Secttor
Hi All
Below is a sample of what I want to obtain. The major problem is that D1 Outer which is the "30"..actually. Assigning it will overconstrain.
The problem is not that I cannot pass overconstrain..this can remain as a parameter(value). The problem is that this family is a nested one (which will become the entity for an array), and D1 Outer is a value from the final family. How can I link it "back" to the nested to get it's value? Is that possible?
Any suggestion is welcome.
rfa attached (revit 2015).
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Replies (7)
Message 2 of 8
robert.klempau
Hello @Secttor,
Ok, let me have a look.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 8
robert.klempau
Hello @Secttor.
If I understand you correctly the sample family is the shared family in the main family and you want to push information from the main family to the sample family.
That is possible of course but you can't get parameter values back from the family that you can use in the main family.
So you can push parameter values to a nested family but not pull parameter values from the family.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 4 of 8
Secttor
Ok..over the night I dreamed a solution..such as link all the parameters from the nested into the final and have all the formulas there..where D1 Outer actually is. This should work. Maybe you can detail a little bit more about that pull from and push to..methods.
Message 5 of 8
robert.klempau
Hello @Secttor
That you can’t use assign the D1 Outer to the yellow marked dimension is obvious.
The Parameter A1 is either set by H2 or D1 Outer and Parameter A2 is set by H2 and also by D1 Outer.
Be aware that A2 gets negative if H1 =0 and D1 Outer is greater than H2. A Dimension may never become negative.
I loaded your family in a new family and linked the parameters.
Then I created an array and linked a parameter for the number of elements and the distance between the objects.
See the family in the attachment
About the push information and pull information to and from the families:
What I did in the example is pushing information to the nested family.
If you had formula’s in that family that get a new value for certain reported parameter in that family, you can’t read that parameter out and do something with it in the main family.
You can’t link reported parameters from a nested family to a parameter in your main family.
Hope this clarifies the push pull example.Smiley Happy
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 6 of 8
Secttor
Hi @robert.klempau
Thanks for your solution!
To clarify a bit :
- H2 can't be smaller than D1 Outer (H2 is the A1 & D1 Outer..that 45 Smiley Happy)..but probably such formula will keep things more safer.
- I was thinking to transfer all formulas into the final family..such way I can investigate easier unproper situations and values that could come after the input. Your solution is an easier way if everything cover any solution in the backside. Thanks!
- One last worry remains regarding the tangency. In Revit 2017..tangency became the easiest dream but I must deliver results under 2015.
If I zoom closer (even I've used a locked 0 value with the plane) that arc looks wierd if strange values comes as input.. and yes..strange values must be covered. I was thinking to have a formula for the radius but..do you know any other trick for doing this ?
Appreciated!
Message 7 of 8
robert.klempau
Hello @Secttor,
1: Constrain the end point of the vertical line to the horizontal ref plane using the Align tool. (select ref plane and tab until you select the endpoint of the line)
2: create a small 1mm horizontal line.
3: create the tangend End Arc between the small line and the vertical line on the left.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 8 of 8
Secttor
Appreciated!
