Announcements
ALINEMAIENTO DE COTAS
esueiras
esueiras
BUEN DIA FAMILIA DE AUTODESK
LLEVO VARIOS DIAS PENSADNO COMO PUEDO ALIGERAR Y HACER MAS FACIL MI TRABAJO EN LA PARTE DE EL DIMENSIONADO O ACOTADO. TENGO VARIAS PREGUNTAS O INQUIETUDES Q NO ENTIENDO MUY BIEN DE REVIT.
1-COMO REVIT RECONOCECUANDO SE PUEDE ALINEAR UNA DIMENSION FUERA DE LA COTA. (POR FAVOR VER EL 1ER SCREEN SHOOT)
2- DE QUE MANERA PUDIERA CONFIGURAR MIS COTAS PARA QUE UNA VEZ QUE RELICE EL DIMESIONADO Y LO SAQUE DE LA COTA POR CUESTIONES POR EJEMPLO QUE NO CABE DENTRO, ENTONCES SE ALINIE AUTOMATICAMENTE.POR FAVOR VEA SCREENSHOT 2.
AGRADECERIA SU AYUDA COMO SIEMPRE.
SALUDOS
iainsavage
1. The setting is in the dimension type properties
2. I don't understand the question as Google translates it - could you explain further what screenshot 2 is indicating?
esueiras
Ok, let me try to explain you in English.
The main problem is that I would like to create some dimensions with the value out of the box (because it doesn't fit into the cote, the number is too large in relation arrow, or arrow but aligned at the same time, please see the screenshot bellow.
I hope that when I drag the number, it comes and tried to align to the line, like when we put a dimension and the Revit suggest to align to the dimension closer to this automatically or something similar.
iainsavage
So if I am understanding, you have dragged the text away and the leader line is not aligning with the dimension line and you are getting a slight overlap in the area that I've circled below. Is that correct?
I don't think there is a way to get the text and leader line to snap to perfectly align with the dimension line.
A possible solution would be to set a distance for the dimension line extension
and then disable the leader option
Then you get this appearance when you move the text:
esueiras
Good Morning @iainsavage
Thanks so much for you explanation! I am agree with you I think that the only way to generate this kind of alignment is as per you show before or manually like I did it time ago but is difficult.
 I just did it like you explain and it works perfectly. So again thank you Sr. @iainsavage 👌
Thanks Autodesk community.
