Aligning / placing connectors to pipe ends
I am working on a conceptual design of some plant in Revit. In conceptual phase, I am placing pipelines "blindly", e.g. without a connection to some tanks and reservoirs, just to check whether the routes are possible.
I would like to avoid rerouting all the piping in the next phase when connectors will be placed into families, e.g. tanks and reservoirs inlets and outlets. You can imagine there will be a lot of rerouting involved, and also Revit likes to do some things in its own way, especially when custom fittings are involved.
My question is, is there a way to put / align connectors to pipe ends when creating / editing mechanical equipment families? Or at least an option to see the situation outside mechanical equipment to place connectors easier, some equivalent to AutoCAD's Edit Block In-place? Imagine like a reverse engineering, instead of connecting pipe to inlet of a tank, I would like to place inlet of a tank where the pipe is located. The tank is going to be custom made anyway, so why not optimising its connections location while designing it?
Thank you for your feedback and have a great day 🙂
