Air Terminal Line Weight - Revit MEP 2012
Is there a way to control the line weight of air terminals that are connected to a system? They take on the line weight of the system (i.e., supply air) and the line weight is too heavy.
Thanks.
CoreyDaun
Do your Duct have differing line weights between Systems? If not, then you can remove the line weight override from the Systems under each System's Type Properties. If they do differ, a View Filter (for the Air Terminals Category and blank rules) will override the System Graphics Overrides; note that the View Filter will also override the Phase Graphics Overrides, so any lighter-toned existing Air Terminals will inherit the set line weight.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Ahhh...got it.
Thanks!
