ADSK file not found
ADSK file not found
stevenson953
ADSK file not found
stevenson953
Hi Guys,
I often get equipment models in the form of an ADSK file.
Usually I follow the following routine although it's been a while since I have had to do this:
-   Open a Floor Plan
-   File - Open - Building Component - select ADSK file-open
-   Load into project and drop in location
I don't recall having problems with this before but I'm getting problems now.
When I try the above I get the attached error that "the file was not found", but it is there for sure.
I have tried several different older ADSK files which I have previously not had any problems with so I'm at a loss as to what's happening.
If I try to open the ADSK file directly into REVIT using Open and I when I select the file I can see in the preview the model so it's there all right.
Thanks for any help that you can provide.
Paul
stevenson953
Answer from another:
I was working from a desktop file and as soon as I transferred the file to a project folder it worked fine.
