Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
Did you mean:Ā
add/remove pipe insulation hatch
3 REPLIES 3
1815 Views, 3 Replies
editing collegues project and his all pipes with insulation are with hatch. I draw few new pipelines and it is without hatch. All pipes have to be the same with or without hatch. So how i can add or remove it?
3 REPLIES 3
NimeshJ
Hello @Anonymous ,
Kindly select pipe with hatch -> Edit Insulation (in pipe insulation panel) -> Check which type of insulation is used.
Now go to pipe without insulation -> Edit Insulation -> Select same type of insulation.
Please let me know if this works.
in reply to: NimeshJ
ye thats worked out!! thanks but is it possible to add those hatches by myself? or its insulation family?
NimeshJ
Yes, why not.
Now I guess these insulation hatches are controlled by filters.
Go to Visibility/Graphics Overrides -> filters -> find filter whose name maybe insulation or something related (or find filter which is having pattern and color as pipe insulation) -> Now you can give any Color, Pattern and Transparency.
Let me know if this is working for you.
Tags (2)
Forma Design Contest
