Add a property into the properties tab
Morning,
I need to know in wich room is located any object that I can select DIRECTLY into the properties tab....I need to read a field named 'Room Number'
I don't know how to add this information, that I can find/read into a schedule, ROOM:NUMBER field.
VERY IMPORTANT: I know how to add a parameter into revit and find it into the Properties tab....
Here, I realy need to know how to add this field to properties tab with the correct values  WITHOUT to have to rewrite them.
Could you please help me find the solution.
Thank you very much in advance,
Greg
Replies (7)
hmunsell
if i understand correctly, you are trying to add the Room Number to a schedule from the architectural model?
  • when your in the Field tab of the schedule
  • select the Select Available Fields From: option
  • pick Room
you should have access to the Room information including the Name and Number.
Howard Munsell
Hi Hmunsell,
Not exactly....
What you have writen is what I've done to have this main information in the schedule.
At this point, we all know that we can get the information Room NAME or Room Number or... inside a schedule.
My question is: how can I get this same Field directly inside the properties tab. How can I add it?
My main goal is to read it from the properties tab when I select any object inside my model.
And........... if we find a solution to this question.........the real big main goal is to export my model to FORGE, to give access to colleagues who works outside and allow them to get that information also in forge.
I know it's a little bit strange....but I seriously don't understand why it's so hard to obtain 'room information' in the properties tab when you select any object.
Thank  a lot for your help
Regards
jeroen_vanmassenhove
I'd suggest to add a project parameter (or shared) and use the power of Dynamo to just 'read' the parameter that you can schedule and write that value into your new parameter.
hmunsell
for what your looking to do id agree with @jeroen_vanmassenhove. a Dynamo script should be able to do that.
Howard Munsell
Dear Jeroen and Hmunsell,
Thank you for your answer which reassures me in the sense that it is possible....
but..... I have no experience at all with Dynamo
Where can I get the 'script' or the file '.dyn' or tuto for that particular question .
Thank you again for your answer
fabiosato
You can go to dynamobim.org, they have forums over there where you can ask for help.
Fábio Sato
Thank you Fabiosato for that advice
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
