Add 2 Pipe sizing in same schedule
arifterbaik14
arifterbaik14
Can i add two type sizing in one schedule?
i want to create like this                                  this what i do in schedule
i create this with text and line
iainsavage
You could do it with a calculated parameter using a formula but you'd need to work out how to round it to get the correct inch value from the millimetre value or vice versa - e.g. 15mm would round to 0.6" rather than 0.5" etc.
You could maybe use nested if..then..or statements to say IF 15mm THEN 0.5" OR, IF 20mm THEN 3/4" etc etc.
I'm sure that something similar has been asked before so if you search for similar posts you'll probably find one with an accepted solution.
RLY_15
The header can be manipulated - if you have a parameter for Dn and a parameter for Inch, you can Group the two column headers and type Size in the new header.
As far as I know, you cannot merge parameter data - so no merging 'Pipa PPR' into a single cell.
