Access System Analysis Results in Space Schedule?
jeremy.mcclanathan
jeremy.mcclanathan
I am trying to calculate space cooling loads in Revit 2022. I have followed the workflow described in "Workflow: Revit Systems Analysis" and gotten an html report that has the loads I need, but I can't find any way to get the loads in a space or zone schedule.  Spaces and zones have fields available called "Calculated Cooling Load", but they just say "Not Computed" in the schedule. Is there a way to access the calculated loads for spaces and zones?
Thank you
Kevin.Lawson.PE
The Revit Systems Analysis method of running loads writes the loads to the "Analytical Space", not the "Space".  If you make a schedule of the Analytical Spaces you'll be able to add the calculated load to the schedule.
If you want to calculate loads and schedule them on your Spaces you can still use the Heating and Cooling Loads engine, but in Revit 2022 you have to modify your Revit.ini file.  Instructions located here: https://rippleengineeringsoftware.com/revit-heating-and-cooling-loads-in-revit-2022/
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
m_clough
Alternately, putting together a dynamo script that updates the spaces with data from the analytical spaces would be pretty straightforward
