A nested family is not hidden by a check mark
<iframe width="640" height="680" src="https://screencast.autodesk.com/Embed/Timeline/bf457211-aa0d-4...
if the part type is tee, then hiding does not work
if the part type is elbow, multiport, ... then hiding works
what am I doing wrong?
fabiosato
I tried Hide Element and it worked normally, I am using Revit 2020.2
Fábio Sato
PavelAnd
Hi @Anonymous. Why is the solution from this topic not suitable? If you add visibility parameters to nested families, then everything will be hidden. I am sending the corrected file as an attachment.
Best regards, Pavel Plotitsyn.
