cancelar
Mostrando los resultados de
Quiere decir:
Zoom to Selection
Zoom to Selection
Zooming to a selected object would aid in the efficiency of coordinating. I've read the rebuttal of using Manage/Select By ID...but this is not a useful work flow it's a work for not having Zoom-To-Selection in Revit it is a work around. Manage/Select By ID is awesome across workflows from Navis back to Revit etc.. WTBS when you select an object in a heavily coordinated model and then choose the Section Box Command...GOD MODE happens and you see everything and nothing at the same time. This work flow requires you to the manually zoom into your selection. Why? It's such a waste of time to constantly be zooming in to your selection, when you're neck deep in coordinating and modeling...Zoom Selected is IN Navisworks Manage. It works as it should...Revit needs this functionality.Zoom_to_Select_3_001.png
10 Comentarios
dplumb_BWBR
I'm with you that it should be a built in function.
But in the meantime: There's an app for that.
Thread discussiing it here on RFO
https://www.revitforum.org/third-party-add-ins-api-r-d/33523-zoom-awesome-returns.html
Tupaia
Hi!
Giving this a bump... simple thing to implement, but effective! I miss it, too!
Btw., "Zoom to awesome" does not work in Revit 2018 and 2019.
Please, thanks!
lingkonn
Hi Guys,
I just created one add-in for Revit 2016, 2017, 2018 and 2019 called Zoom to Selection which should do the job.
No aplicable
Yes please. Seconding this one with both hands.
No aplicable
Ditto x 1000000. Such a simple feature that makes workflows so much more efficient. While I appreciate the work of kind strangers who have developed add-ins, that route doesn't really work when, for instance in my case, it's a large firm and to download add-ins requires you to submit a work ticket...
kcannon7SM62
Revit has "zoom region" and "zoom to fit"; why doesn't it have "zoom to selection"? This would make many workflows in Revit much more efficient. Please add this functionality soon!
No aplicable
yeah what the hell revit
stian.engelstad
Yet another feature that should have been standard upon release and is yet to even be tought of even 4 years after being suggested.
stefanome
Zoom to selection does exist: select something and click on the cube.
It works, but there is no keyboard shortcut and it may change the view orientation.
It does exist also in the APIs: UIDocument.ShowElements().
Making it an out-of-the-box command would be very easy.
I made my own command on my own add-in, and I can easily define a shortcut for it, but this is such a basic feature that should be part of the out-of-the-box toolset.
Upvoting this idea.
ynemchev
 do you mind sharing the Code? I'm stuck in the writing of such command... so far, not so good...
Enviar idea
