在机电模型组里进行出图前标注(Mark before drawing in electromechanical model group)
在机电出图,需要进行标注,如果是有很多标准层,我们就可以生成模型组。相同的模型组的特性就是改变一个模型组,其他相同模型组就会进行复制,这样我们出图标注就可以标注一层就可以了,方便快速出图,避免重复性工作。可现在的revit版本,不支持在模型组里进行标注,无法同步到其他相同模型组里。
In electromechanical drawing, we need to label, and if there are many standard layers, we can generate model groups. The characteristic of the same model group is to change one model group, and the other same model groups will be copied, so that we can mark one layer in the drawing, which is convenient to draw quickly and avoid repetitive work. However, the current version of revit does not support annotation in model groups and cannot be synchronized to other model groups of the same type.
