Currentely, it is imposible to import meshes from Memnto to Revit.
Why to import meshes int Revit ? See three raisons below :
1- when you will try to make a rendering on points cloud ==> the points cloud disappears,
2- you can't have shadow on on points cloud,
3- in perspective view, you can see through points cloud,
Full explanation :
http://forums.autodesk.com/t5/memento-general-discussion/workflow-memento-to-revit-software/m-p/6295...
An idea : could be possible to implement import FBX format capability for Revit for instance !
Olivier
