Wire Tick Mark customization
It is more common practice to group circuits with tick marks, so instead of being GGHHHHNN it would be GHNGHHHN.  Also the nomenclature of a comma between circuit numbers for some has a separate meaning.  It would be really beneficial to have some ability to customize how the circuit numbers are displayed.   As 1,3,5   could mean 1-3,5 or 1-3-5 or 1,3-5. Some companies use a / instead of a comma.  There isnt one set standard, so some ability to customize the syntax is necessary.
4 Comments
RAbraham9AVH9
While preparing Electrical layouts, we show wire / conductors by tick marks. The order of tick marks appearing in Revit is wrong. It should appear in reverse order.
Tags (1)
jacobfZFBFB
We use tab to toggle between what we can select. When we have multiple items close together, it would be helpful to have a reverse tab selection if we are constantly mashing the tab key and accidently pass it in frustration.
Lachlan-JWP
Holding Shift while pressing tab will do that. That's a standard windows feature.
crapai
Tick mark order needs to be adjustable.
