Wire fabrics cut list
every day I'm experiencing problems with construction companies asking for wire fabrics cut lists! No one wants to do this manually.
Please Revit developers, find a way to implement something similar to this in version 2021.
Kind regards!
3 Comments
caden.armstrong8HUVJ
Lots of Fab shops use tools like Sigmanest to do sheet nesting. Even Autodesk has TruNest.
I don't know of any CAD that will provide nested cut lists without some kind of addin.
How did you make the above cut lists? Did you just do it manually?
mark.martin.se
@caden.armstrong8HUVJ
The above cut list is from Sofistik addin for Revit.
A lot of detailing companies use other ACAD based addins. One of those has a cut list like this:
(this is how it looks in model view)
(this is automatically done by software for construction site purposes)
We use this ACAD addin from 1995.
Kind regards!
mehermnifi
You can use sofistik by generating schudule and use the option import schdule as dxf then you can decompose it scale it and change the text style .....
