cancelar
Mostrando los resultados de
Quiere decir:
Welds Hatching and Steel Member Numbering
Its Better to make Fillet welds  as 3D objects in the model and  enables drawing of these welds to be
hatched in shop drawings automatically . also an automatic numbering  of steel member column, beam, brace, ..etc
4 Comentarios
AntDrt
Hello, revit isnt very good for Steel fabrication drawing.
Best way is to export to AdvanceSteel with Addon and make welds on it.
Then re-import the Advancesteel model in revit.
YarUnderoaker
Advance Steel is glitchy crap. We need Revit based steel fabrication software. Moreover, Revit potentially has everything for this.
daniel9j9tomas
Community Visitor
Very Good Idea and totally agree with that
Currently it's only a + sign so you can't show weld length :cara_asombrada:
farzanbayat74
If this idea happens life will be much easier for us structural engineers :cara_con_los_ojos_en_blanco: @kimberly_fuhrman-jones
best way is to make 3D welds parametric in the connection families. drawing weld hatch manually is very laborious.
Enviar idea
