Walls have framing.....
Walls have some kind of framing (unless they're concrete and/or block).  So why does Revit not include framing in the walls?
Allow us to specify the
  1. top & bottom plate sizes
  2. stud size & spacing
  3. what size header is needed (this would probably need to be some kind of formula:  Opening< 5 = 2 x 6, Opening< 0, 2 x 8 etc.
  4. how should the top/bottom plates tie together at the corners.
Allow us to override the framing members if needed (like we can with trusses).
Similarly:
  1. We should be able to tell a roof to place a specific truss at a specific spacing.  The roof would need to have "regions" one region might use a truss while another region might need rafters/joists.
  2. We should be able to tell a floor to place a specific floor joist at a specific spacing.  As with the wall, it would need instructions for dealing with openings (i.e. stairs) so that it can place the required headers.  There'd have to be a way to enter a maximum joist length and a required overlap length. Revit would need to place two joists sistered together if the floor were to require a longer joist.  We would need to be able to manually move the location of the overlap so long as both joists stay within the length tolerance.  Then we could place a beam and any required posts under the overlap ourselves (I'm not suggesting that should be automated too).
This would help with creating a correct model and with the process of generating accurate sections.
25 Comments
ConstantineC
I  have just submited this idea which is made of two basic points :
1 - Walls (simple and composite) to embed curtain walls as framing, not just as openings
2 - Curtain walls to host structural framing, not just mullions.
Please vote for it if you think its needed.
https://forums.autodesk.com/t5/revit-ideas/option-for-walls-to-embed-curtain-walls-as-framings-not-j...
Autodesk, its 2023 and you still have not fixed this! WHY !
@kimberly_fuhrman-jones 🙏 please give this one a push up the chain 😃
m_barnett
wr.marshall
Though not specifically about framing but related Autodesk need to allow  short lines like this idea: Allow us to Draw Small Detail and Model Lines - Autodesk Community
this is an extract from a framing system that uses 0.6mm thickness of material as apposed to the 0.8mm currently allowed by Revit
as mentioned there too it can have an effect on designs like to name a few:
  • weight per individual item
  • weight for a group of items
  • Dimension spacing between items
  • Dimension Tolerances in tight spaces
