Railing hosted to a Topography (non-flat) surface.
Would very much like to see railing objects & walls able to host directly to a topography. And the ability to extrude a sketch shape directly off the topography surface with thickness. Not talking about the building pad either which only have value if the site is flat, which seldom happens.
[Edited to remove "or Wall" from title]
6 Comments
Rafael.Moraes
It will be a great idea if Revit could model walls that follow toposurfaces. If possible, create a new tools called "fence" (some kind of railing) that follow the toposurface will also be great.
janine.gualberto
Observer
Great ideia!!
And floors would be nice too! So we can design the sidewalks along with the project...
sasha.crotty
Thanks for adding your idea! I'm marking this issue as implemented as starting in Revit 2018 it is possible to host railings on topography. I recommend filing a separate idea for attaching walls to topography.
Tarek_K
Status changed to: Gathering Support
Tarek_K
