cancelar
Mostrando los resultados de
Quiere decir:
Wall Join: Preference to join to same material
When drawing walls (particularly finish walls) they automatically want to join to other adjacent walls, despite an intersection with walls of the same type and material. Sometimes trimming/adjusting the wall join works, and sometimes it doesn't.  This incorrect model behavior also affects counts and schedules.  Disallowing join also displays incorrectly, since then lines are seen in each corner
Example:
Base wall is metal stud with Gyp.  Finish wall is ceramic tile.  The Ceramic tile wall bypasses the other ceramic tile wall at an inside corner, trying to join with the stud of the ceramic tile wall.
3 Comentarios
No aplicable
This problem also bugs me, but I have adapted how I place these "interior" wall linings to reduce this happening.
  • If it is a single run, I use the new Allow/Disallow option in the options bar and select disallow
  • If it is all around the room I use a rectangle or...
  • I model the walls away from corners and then go around and trim.
not ideal, but it almost eliminates this really annoying problem.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
El estado se ha cambiado a: Archived
Enviar idea
