wall join behavior when using mitter
when you use a mitter join, between two walls of different heights the result is something like this:
I think in every situation this is not correct. The correct should be something like this:
 or like this:
 or like this:
 depended on where the walls were extended by the user.
Right now the only way to achieve this is by creating separated walls, which is a little painful.
I think the developers should consider this in feature 3d wall improvements.
2 Comments
asf.arq
Hey, @ar00302 !
Doesn't the wall join tool resolve this issue? Why would you rather use "mitter" instead of "butt" or "square off in this situation?
regards,
Arthur
wr.marshall
Autodesk Customer Advisory Groups
