Hello to everybody,
i know to get wall gross areas and volumes
there is some turn arond like copy and control walls
or move booleans outside the wall volume dinamically
with parameters associated to dimensions;
but these are just turn around;
i submit the "Revit Idea" or to extend the "Cuts Geometry Parameter for Voids" parameter function to walls, roofs, ceilings, floors....
or add a parameter that is able to switch on/off the cut of the subtraction solid with the wall;
now "Cuts Geometry Parameters for Voids" works only if the subtraction solid is NOT subtracted to the wall and you have to:
- add a instance visibility parameter to control "Cuts Geometry Parameter for Voids" from model ".rvt" file;
- cut one by one walls with windows or door;
- if you have modeled walls side by side separtely you have to cut all the walls with the same window or door;
- if you have more subtraction solids into the window or door you could get unexpected results with the walls modeled side by side, because it works correctly only if the sub-solid is trought all the walls;
Fulvio.
