Visibility parameter for groups in family editor
It's currently impossible to add a visibility parameter to a group instance.
To have a Visibility parameter available for groups would greatly simplify the creation of families.
One example where this is necessary is when you're creating an array in a family. Arrays need a minimum of 2 elements to work.
But in cases when an array only needs 1 element, we should be able to set the second element to invisible.
Something in the likes of "Array < 2" uncheck the visibility of that last element.
But I'm sure there are other examples, when creating families, where this function is desirable.
6 Comments
scbunker
I agree this would be helpful. However, I can usually get around it by using nested families instead of groups. I find nested families are a bit easier to control anyway.
Kimtaurus
@scbunker I try to use nested families as well. But this Idea is mainly for when you have an array. If you only need 1 instance, you can't just hide the second instance.
RFreund
Has this functionality been implemented in future editions?
Nested families seems like overkill in some instances.
MVE1112
I agree with Rfreund,
I find myself making inception style families "We must go a layer deeper!" just to do something that could be done with group visibily.
MVE1112
agreed
Select a group and hit the Edit Group button. Now, you can control the visibility of groups.
