cancelar
Mostrando los resultados de
Quiere decir:
Views used on sheets display in project browser
I would like to be able to differentiate views on sheets within the project browser.  Simply graphic font application would be great, have every view on a sheet display in a bold font, or even another color.  This way as you go to add multiple views from the project browser (which is so much faster than the pulldown) you can clearly identify which views are already used.
5 Comentarios
No aplicable
Would hiding views that ARE on sheets not work for this purpose? Filtering out views on sheets from the view section of the project browser has worked for me in the past, and prevents this confusion.
twebb4CYQY
Thank you adcherry.  While I realise there are workarounds for this and many of the ideas on this board, in this case my overall preference is the project browser remain the one location where you can find everything all the time regardless of it's status in the project.
ipselute
I would prefer a little paper icon next to all view names already placed on sheets. And when you hover the mouse over that icon a small info-tip to appear and specify the sheet name/code.
chanel.graham
Community Visitor
It would also be great if the project browser was set up like the ribbon, with tabs for each category; views, legends, schedules, sheets, etc. (similarly to how ACAD has its palettes or properties)
YAY TABS!!!YAY TABS!!!
El estado se ha cambiado a: Implemented
We are pleased to say that this was implemented in Revit 2023! Thank you for your contribution to improving Revit!
 -The Factory
Enviar idea
