View Tabs and undocking views.
I want to be able to use all my screen and see all the views I have in tab form.
It would be amazing to un-dock a view from within Revit then place it on another screen. To do this now you have to "Restore-down" your Revit, then stretch it across multiple screens. Then set you Revit views up in the current session.  If something happens it goes away, then you must repeat the strenuous task to rebuild it the way you had it.
5 Comments
lionel.kai
@harlan_brumm @sasha.crotty This should be marked as IMPLEMENTED (in 2019), but there are some other ideas to complete Autodesk's unfinished implementation of tabs and out-of-frame windows:
As @lionel.kai  stated, this was Implemented in Revit 2019. Thank you for your submission!
Tarek_K
Status changed to: Gathering Support
Tarek_K
mmyersER3J5
What would make this happen even if I was using Revit 2024? This is my issue.
