View.GetFilters should return Filters in the order they are applied to a view
The function View.GetFilters should return ElementIDs of the Filters in the order they are applied to a view in the visibility graphics dialogue for that view.
This order is important to know as the higher filter takes precedence over the lower filter. Two filters may be applicable to the same element but if they are contradictory (different colours of surface fill pattern etc.) only the highest one will be applied.
https://forums.autodesk.com/t5/revit-api-forum/get-the-top-view-filter-applied-to-one-element/m-p/76...
5 Comments
rossen.hristov
This is really crucial for us as well. I need to decide whether an element will be visible in VRay for Revit depending on the filters applied, but they are always returned in the order they were created and not in the order they appear on the screen. If Revit knows the order, the API could easily return them in the same order so that other plugins can use them in the same manner as Revit does.
harlan_brumm
Status changed to: Accepted
harlan_brumm
This has now been implemented in Revit 2021.
-The Factory
Tarek_K
Status changed to: Gathering Support
Tarek_K
