vertical angled/sloped walls
Figure out a way to angle/slope a vertical wall out of plane without using a 'mass'.
2 Comments
If you had done a search prior to creating a new idea you would have found out that this is an already "Accepted Idea" and is on the Revit Roadmap.
https://blogs.autodesk.com/revit/2019/01/23/revit-public-roadmap-january-2019/
So there is no reason to create a new idea....it is in the works.
Thank you for your Idea submission. This feature was Implemented in Revit 2021.
