Used Template
Used Template
Hi All, we need to have a way to know which template has been used for existing project file.
1 Comment
Mike.FORM
I feel the best way to do this is to just add a "Project Parameter" assigned to "Project Info" called Template used and just set the value in the template so that every new project has the info filled out already.
If you update your template then you can just update this value in the new template.
It is not really possible to figure out what template was used for an existing project without analyzing all the standards and everything else in the project and trying to compare to a template.
