La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Use the mouse wheel to scroll the cut plane in a section view
Similar to moving the “cut plane” of a section box, I would like to see an option to use the mouse wheel to “scroll” the cut plane of a section view (forward and backward).
Just to confirm understanding of this, are you referring to the view depth of a section line, or the actual section line position?
If regarding the view depth then have 2 additions to this feature
(1) Same feature for plan views
(2) Need a setting to control the speed/increment of the cut depth
Question how would you differentiate between controlling depth and zooming. Perhaps right click and select option "view depth/adjust view depth..." When completed right click "finish/exit..." or tick on special ribbon... If you have not done the mentioned steps then you would be in zoom mode.
I appreciate your thoughts on this... I'd like to clarify your comment "by default rolling mouse roller will zoom in/out". Rather than zooming, rolling the mouse wheel would move the cut plane forward and backward as an aid to the user's visualization of relationships (intersections or conflicts) between model elements much the same as a medical imaging technician would move a 2d cut plane through the 3d scan of an anatomical structure to aid their understanding of that structure.
