Issue: Projects that use trusses normally have a truss top chord plan and a truss bottom chord plan. This is because trusses are normally in excess of 8'-0" deep. Currently you can only connect members such as purlins and bottom chord bracing to the bearing chord selected in the truss instance properties. (see below)
If additional members need to be attached they need to be assigned to a different level. these elements dont connect to the truss and as such, their symbolic offsets dont work creating graphical representation errors on plan. Because they dont attach, they also do not move with the element if trusses move during the building designs evolution.
Solution: allow framing members to attach to both the top and bottom chord of a truss
