True TRANSVERSAL Multicategory Schedules by LEVEL/PHASE
the power of Revit schedules is great, allowing a global perspective to manage the contents of our projects, especially the multicategory ones, but they lack a couple of capabilities to achieve this true cross cutting vision.  unfortunately, Revit uses a few different parameters to handle levels, depending on each category.  most of them use "Level", but walls use "Base Constrain" and roofs use "Base Level".  that small dispersion prevents a whole level organization.  a simple solution would be to add new "full level" argument to join those three parameteres in a single column/filter.
in the case of "Phase Created/Demolished" it should be much easier, since they actually have the same parameter, so it would just be a matter of adding it, that's it.
2 Comments
JordiCC245
the same for "Elevation from level", "Offset from host", "Base Offset", .. and all those parameters with the same meaning and different words or Built-In parameter
tgoodwinX2SUJ
We really shouldn't have to vote on stuff like this, please just fix all the obvious fundamental issues with your implementation of the overarching idea of a construction database.
That being said, this title is not doing this idea any favors. "Merge the various 'level' parameters and allow tagging and scheduling of them" would be my suggestion.
