Show only
Search instead for
Please let columns and rows be able to be switched. Often the parameter description name needs some length and this would be much easier in a vertical schedule than a horizontal schedule. Most of our standard schedules are vertical type so we are still using detail lines and text and missing out on the parametric power in Revit. The Revit default horizontal equipment schedule is very hard to get right. It looks terrible because different columns will have different widths to fit the parameter description, and for most equipment ends up being too wide for the sheet, especially when our client makes us work on a 34"x22" sheet.
This would be so useful! Our office has found some tedious workarounds when this is absolutely necessary, but it would be terrific if this were an option OTB. We are always in favor of more flexibility to show information the way we want to.
Eu apoio isso plenamente! Extremamente útil para Elétrica e Dados. Em projeto de Dados tenho mais de 200 pontos, em que os cabos RJ45 que tem que ser calculados em Colunas, porém depois é necessário transpor as colunas por linhas.
