please add (surface) Transparency option for Imported Categories in visibility graphics. This would help especially for dwg files. Without changing the transparency of these manually via manual graphics override, it is many times impossible to select revit elements when dwg is set to foreground, even though there is nothing visible in the dwg "covering" revit element. This should be easy task since it is possible to do that, but manually only for each instance.
