Toposurface, contour lines, subregions
Make it possible to override contour lines of toposurface
add subcategories for subregions
add subcategories for pads and toposurface that is generated by pads
Sometimes toposurface is displayed as white area when there is a pad
2 Comments
samuelsanf
About Contour Line, actually you can modify by Site Settings windows.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-M...
elzahaby.m93
Observer
I am not talking about the lines which display the height but the contour of the toposurface itself (the edges) and when having a pad the lines created by the pad. And also lines created by subregions. Subregions create 2 contours, those of the region itself and within the toposurface there are other lines. So by overriding the subregion you face the problem of having a another Line by the toposurface itself that can't be overridden at all.
It is impossible to override any lines with the line override tool.
