Toposolid (terrain) Analysis Themes: Elevation, Slope & Aspect
Toposolid editions for site design would be a lot easier with visual hints for editions: lot of times understanding what points are above/under/at certain height from other model elements, or to confirm toposolid surface between allowable slope range or at proper direction for drainage; and requires to pivot a 3D view to see from diferent angles.
https://www.arcgis.com/home/item.html?id=58a541efc59545e6b7137f961d7de883https://www.arcgis.com/home/item.html?id=58a541efc59545e6b7137f961d7de883
 (examples from ArchGIS)
With analysis themed pallete  for Elevation, Slope and Aspect of toposolid (like Civil 3D, InfraWorks and Revit Point Clouds) on revit views would be a lot easier to get desired results on site design by manual manipulation of points.
https://www.youtube.com/watch?v=6K_U27Nwca8
1 Comment
aizaiwutuobang
其实从未来发展的角度来说,CIVIL3D是基于CAD来的。CAD不能承担BIM的重任,revit作为BIM的先锋理应将CIVIL3D的能力承接过来完成BIM整个生命链的。从场地、道路、建筑、景观绿化、结构、机电等全方位的覆盖。一个平台承接打通所有。
