cancelar
Mostrando los resultados de
Quiere decir:
Toposolid Height Offset from Level
Please let us pre-define the Height Offset From Level when generating a Toposolid from imported mesh/points.
I generally I like it when the Toposolid has zero height offset from the level that we call Datum or Sea Level.
However, at present, it seems that the elevation height from the lowest imported point is used for this and there is no way to later change the offset without changing all the elevation heights with it.
1 Comentario
aubrey_tucker
It's really odd that there is a height offset at all for the toposolid, especially when there is no way to control the value at during the toposolid creation dialogue. This is especially weird since the offset is affecting the bottom plane of the toposolid and when its value is changed, the entire toposolid moves with it - very unexpected behavior. Defining a bottom value for the toposolid that isn't the sealevel would make a lot more sense and keeping the top surface as the inherited faces from the topography.
Enviar idea
