Currently, when writing big blocks of text that have tab indents and bullet points, the text seems to shift as you go to re-edit the block. This then means I need to go back through the big wall of text, and realign everything to how it was before because Revit seems to shift everything around. In AutoCAD, this doesnt happen. No matter what zoom you are, the text alignment will always remain the same.
This bad text functionality in Revit has costed me tons of time, as we have text blocks in our template that need editing for each project (specifications template sheet that gets information taken away from it for each project depending on what that project uses).
Essentially, I'd like Revit's text functionality to improve so that the text doesnt shift every time you go to edit it.
