cancelar
Mostrando los resultados de
Quiere decir:
Temporary View Properties - Save custom parameters
Hi!
I hope this will be clear since my Revit is in french so maybe the names of the tools aren't exact.
I would like to be able to save and easily access custom parameters for the Temporary View Properties (TVP).
Exemple :
I need to view the  architect model for a short period of time and from different kind of views (sections, elevation, plan).
For me, it is quicker to use TVP than to go in an other view of coordination (since I would have to duplicate a lot of views) or to set an other View Template for a short time (since I would have to create multiples).
But since I need to do the same steps again and again, I think a saved setting would be nice.
The problem would be to save only the changes we want/need (in my exemple : only the "Revit Link" tab) and not the entire VG settings (since it will be used in multiple kind of views and they are all set differently).
Maybe there could be a "Ignore" check box on each tab so we could select them to be ignored (so they would not be override when using the TVP) ?
Or a way to select only the settings we want to be overriden.
See the image below for the idea :
Thank you!
1 Comentario
Evalucia
To clarify a bit :
It doesn't seems to work to create a View Template to show linked model with "By Linked View" and use it in the TVP.
The settings comes back to "By Host View" when applied to a TVP.
See image below : Capture_2.JPG
Basically, the problem is that the template isn't able to adapt itself to different views.
If this could work, we wouldn't need an other way to save TVP settings.
I posted my idea too soon, sorry.
Enviar idea
