Tag text align
Tag text align
To add to TAGS the ability to align to LEFT, RIGHT, CENTER as desire and, to be able to align a TAG to TEXTS too.
Also, if a TAG has a leader with a horizontal portion, for some reason, cannot be align horizontally. Please fix this.
3 Comments
pascal.robben
Yes please! This would be a big improvement.
This alignment should be easy, using left, right center as alignment between tags and text.
Now it's always moving near desired position without having the snap points.
MOR-ConorMacken
Ideally the alignment would follow the attachment point of the leader, like leaders in AutoCad.
r0834638
Community Visitor
Dear Autodesk Revit Team,
I suggest adding a Tag Alignment Tool to streamline annotation placement. Aligning tags for elements like beams, floors, doors, and walls is manual and time-consuming. An automatic alignment feature—similar to aligning model elements—would enhance workflow efficiency and improve drawing clarity.
This tool could offer options for horizontal, vertical, and evenly spaced alignment, reducing manual effort and ensuring consistency. I appreciate your consideration and your continued improvements to Revit.
Best regards,
Zaid Adnan
Tags (1)
