Show only
Search instead for
It would be nice to be able to snap leaders to angles at different increments, like 10° or 15° increments, etc. Right now I just draw lines at the angle I need and then eyeball the leader to that, which is incredibly tedious.
I would really be excited if the developers could make the annotation leaders snap to the snap settings.
We have a rule that the leaders should be created at 45 degrees where possible, however the leaders do not snap to 45 degrees nor do they show the angle.
Please if you are passionate about this function like this idea so we can have it implemented in the next release.
I'm sure this is not a discipline specific request but a general global documentation function.
I like the idea of snapping to an angle, it would be good to have the ability to adjust angle increments, similar to how you can do this within the AutoCAD options.
We have a similar rule, although the angle can be different, it should be consistent throughout the project. Additionally, leaders should line up horizontally and/or vertically whenever possible. They should all have the same landing length as well.
Horizontal and vertical snap function works well in Revit. Yes agree don't mind the angle being not 45, but should be consistent approach for the documentation set. We steer away from horizontal and vertical as it can be confused with drawing geomentry, so 45 is our standard.
Expect exceptions... 'one size fits all'... never actually does
Have you tried our new tool? It allows you to align several tags according to any angle you like, rearrange them in case they are overlapping, and stretch their texts so that they all have the same landing distance.
It's very cheap compared to other paid Revit Add-ons and I think it is what you're looking for.
One thing that any kind of drawings should achieve is 'Clean Presentation' / 'Readability'.
The way current Revit do not provide an option for us to adjust angle of text and annotation leaders bothers me for many years. It should be able to adjust angles or enable angle snap (like 15, 30, 45 degree or so)
I have seen someone does the plugin but it is quite costly and I think such a simple idea should already be implemented in Revit natively.
Go to the Autodesk app store and purchase Bird Tools Tag Alignment tool. $10.00 per user per year. Super cheap and solves all of this... Bird tools also has a Tag stacker tool for another $10.00. So $20.0 a year per user.. This one is when you have multiple tags with the same value and want to stack them on top of each other.
While I agree with you Autodesk should automatically have been having this feature. This is a feature we have used since prior to Revit even being purchased by Autodesk...
Also you can do it in Revit but complete manual and you have to do every tag individually!!
