cancelar
Mostrando los resultados de
Quiere decir:
Tag By category
Tag By category
Hello
Select the type of tag from the list type selector
5 Comentarios
Kimtaurus
Is this a question or an idea? You're going to have to elaborate your post.
GHASEM_ARIYANI
 hello @Kimtaurus
both. I think that everything in the clip is obvious.
Kimtaurus
@GHASEM_ARIYANI No it's not, what are you trying to do?
To set the default tag types when using the Tag-by-category tool, you need to got to Annotate > Tag > "Loaded Tags and Symbols" and set the desired types.
To change the type of a placed tag, select the tag and choose a different type from the drop-down menu.
@sasha.crotty Could you move this post to the forums? Thanks.
GHASEM_ARIYANI
Hello @Kimtaurus
I know these things. If you look at the clip you will notice.
thanks anyway
Kimtaurus
I'm still not sure what your problem is. It looks the same in my Revit.
Please explain, step by step, what it is you're doing or what do you want to do.
On your snapshot: those are your Floorplan Types. That has nothing to do with "Tag by category".
Enviar idea
