cancelar
Mostrando los resultados de
Quiere decir:
Tabbed views - Tabs - Tab bar for open Views
Navigating open views in Revit is a bit cumbersome. You can tile your views, use the Project Browser or use the 'Switch Windows' button, but nah... I mostly use CTRL-Tab to find the open view I need. So what I would like is a tab bar, showing a tab for each open view. Just like the newer version of AutoCAD can display a tab for each open drawing.
As an alternative, when clicking 'Switch Windows' there's an option 'More Open Views'. Unfortunately, that window closes if you click a view. Make that window sticky. I.e. let me dock it somewhere on my second display.
25 Comentarios
lionel.kai
@Anonymous I thought I'd already made that Idea (I know I posted it to the developers), so I made one now. In addition, there are some other ideas to complete their unfinished implementation of tabs and out-of-frame windows:
Zwielehner
May I through in this little plugin? It shows all the open tabs with thumbnails, grouped by file. Would that work for you?
Revit Window Browser ++
Disclaimer:  I'm the developer.
jdonatoWWAHL
Looks like this issue was solved in the parallax plug in.  Having the ability to group and make different projects colored will be a huge help in organizing when we have multiple projects open at the same time.  we are often pulling information from one project and bringing it into another.
Tabbed Views+ for Revit – Parallax Team
Tarek_K
El estado se ha cambiado a: Gathering Support
Tarek_K
El estado se ha cambiado a: Implemented
Enviar idea
