Tab select linked lines
When selecting lines that have common start and end points, you can use the TAB key to select a whole chain of such lines thus voiding the need for polylines in Revit. I would agree if Revit took into account that these fragments should, other than some of their points, also have type or colour in common.
Fwiw, I stumbled upon this behaviour in Revit 2019.2.3
The idea is to allow some adjustments to the TAB select function.
2021-09-29 07_52_11-Autodesk Revit 2019.2.3 - [a19#wand.rfa - Sheet_  - ].pngUsing the tab key in this example on one of the black lines will select the other black line and the top half of the hexagon.
